difference of licenses on Master - standby controllers
Hello Experts ,
i see difference in the licenses on master and standby controllers in my network, right now the standby controller has become master and has all the access points registered on it .   from my experience i have seen that usually you install the licenses on the master controller and the standby synchronizes the licenses from the master, but i see a lot of difference when i go to the master and standby controllers.
i am adding the outputs from both the controllers, please have a look and advise.
Re: difference of licenses on Master - standby controllers
Did you already turn on centralized licensing?  By default it is not on..
is there any command which can be turned on to enable centralized licensing on the controllers ?
does that need to run on both the controllers , master and standby ?
