different ip range between controller and ap
I deployed 30 IAP-93 and one 3600 controller... I need different ip range between controller and access point through vlan without touching the existing switches...
Re: different ip range between controller and ap
If you are going to have devices on a different VLAN than another, you need a device to route between them, period.  Since you cannot touch the switches, which device will do the routing?
Is it possible to push the ip addr through tunnel b/w controller and ap...
Do you want the wireless clients to have a different ip address range?
