Contributor II
disable an SSID from a particular radio
How can I remove an SSID from a specific radio.
Re: disable an SSID from a particular radio
Well yes - you can disable a radio in the rf profile for an ap/ap group, but that will in turn effect all the ssid's defined on the specific AP or the AP group.
John Solberg
-ACMX #316 :: ACCP :: ACSA
Aruba Partner Ambassador
Intelecom Group - Norway
Remember to Kudo if a post helped you! || Problem Solved? Click "Accept as Solution" in a post!
You can do this by creating an AP-Specific Setting:
Configuration> Wireless> AP Configuration> AP Specific.  Click New and Select that AP.  Under the Wireless LAN setting, just remove the Virtual AP that corresponds to that WLAN.
Colin Joseph
Aruba Customer Engineering
Hello Colin
I have been tring to do this in on a 7005 I have had success just the way you explained it in this post for prior editions. This is how I did it. But I cannot find out how to do ths in  version 8.
I did get as far as 1 SSID and only 5g on both AP and second SSID 5g and 2.4 on both AP but I am trying to turn of the 2.4 radio on one of the AP's and I have no luck finding this.
Thank you in advance.
