disable ftp port controller
Is there a way to disable ftp port of the controller?
At least on alcatel switches you can enable or disable this port whenever you want, which most of the time you enable it when you need to upgrade the switch.
And i got a clietn which is asking me to disable this on the controller
Alternetworks Corp
Re: disable ftp port controller
You would use a service ACL to do that:  http://community.arubanetworks.com/t5/Controller-Based-WLANs/What-is-the-function-of-service-ACL-in-6-3-or-How-do-I-block/ta-p/176402
The FTP implementation on the controller only allows devices to download AP code.  It does not allow uploads.
Colin Joseph
Aruba Customer Engineering
