- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
06-14-2017 08:14 AM
I am currently facing the "securelogin.arubanetworks.com" certificates has been revoked when i open the IE browser. This occurs only to some randomly chosen laptops.
On the other hand, I have also taken some other laptops to test and they are able to pass the certificate without any issues. No sign of certificate revoked. After the authentication, it goes to the next screen which is the guest wifi login screen. for those pass the authentication. On those that have no error, I have checked that the certificate is still valid till Aug 2017.
All laptops have the same IE versions.
I am curious and confused why it occurs and affects only some laptops, while the rest of the laptops are able to pass through(no certificate revoked diplayed) .
Apprreciate and thanks for your help in advance
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
Re: display certificates revoked randomly on some laptops
06-14-2017 08:23 AM
Victor Fabian
Lead Mobility Architect @WEI
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
06-14-2017 08:24 AM
You should not be using the default controller certificate.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
06-15-2017 12:08 AM
Hi Tim and Victor,
Thanks v much for your help and advice.
Will get a publice certificate for that.
Regards
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
