display how many APs are assigned to each ap-group?
  • 1.  display how many APs are assigned to each ap-group?
    Posted Dec 27, 2016 09:42 AM
    Can anyone tell me an easy way to display all configured ap-groups and how many WAPs are assigned to each?
    We have a lot of sites coming and going often and I am looking for an easy way to audit configuration and delete unused groups.
    I was hoping since Aruba does a good job of displaying configuration pieces and how many REFERENCES there are for each (example: "show aaa profile"), that something like this would be easily accomplished as well.  I checked with our VAR and they do not know a way and I haven't been able to find anything on airheads.
    I am looking into putting together a script to parse the ap-group list and essentially count APs assigned to each, but was hoping there might be an easier way.
    Thanks!
  • 2.  RE: display how many APs are assigned to each ap-group?
    Posted Dec 29, 2016 11:42 AM
    show ap group
    show ap database group <group-name>
  • 3.  RE: display how many APs are assigned to each ap-group?
    Posted Dec 29, 2016 11:52 AM
    yea, I know about those commands but not quite what I was looking for...
    show ap groups lists all the ap-groups.
    show ap database group xxx lists all waps in that specific ap group.
    I guess I was looking for a way to view a summarization of the ap-groups to see how many waps are assigned to each in a single command.  We have hundreds of AP groups and it would take a significant amount of time to check each one.
  • 4.  RE: display how many APs are assigned to each ap-group?
    Posted Dec 29, 2016 12:00 PM
    You could dump the output from 'show ap database' into Excel, do some clean-up, do text-to-columns and then create a pivot table.
