Contributor I
do I need a license to be able to create policy and role for guest users.
im configuring captive portal for guest wireless. i configured everything right but when i get to the polices and roles inorder to prevent guest network to access my internal network, I can create a policy by name but i cannot add rules to the policy. also I cannot assign a firewall policy to a user role. the button are simply not there.
do I need a license to be able to do that, or there is a problem with my controller?
thanks in advance.
Frequent Contributor II
Re: do I need a license to be able to create policy and role for guest users.
To use the Next Gen Firewall, you need to have instaled PEFNG license on your controller.
This enables you to set up roles with policies.
-ACMX #352-
Remember to Kudo if a post helped you! || Problem Solved? Click "Accept as Solution" in a post!
http://www.arubanetworks.com/pdf/products/DS_PEF.pdf
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Contributor I
thank you very much. so there is nothing wrong with my controller. all I need is to purchase a PEFNG license. :)
