Frequent Contributor I
eapol-pkt-drop when roaming from AP-105 to AP-124
The following debug is from a client debug output when it roams from an AP-105 to an AP-124: Mar 14 10:25:12 station-down * - - Mar 14 10:25:13 eapol-pkt-drop * - - unknown ap Mar 14 10:25:18 eapol-pkt-drop * - - unknown ap When roaming from an AP-105 to another AP-105, client debug is as follows: Mar 14 10:11:03 station-down * - - Mar 14 10:11:03 station-up * - - wpa2 aes Mar 14 10:11:03 station-data-ready * 244 - Mar 14 10:11:03 wpa2-key1 <- - 117 Mar 14 10:11:03 wpa2-key2 -> - 135 Mar 14 10:11:03 wpa2-key3 <- - 151 Mar 14 10:11:03 wpa2-key4 -> - 95 It appears that the AP-124 does not associate with the client (i.e. station-up). Are there any known issues roaming between different model APs? Regards, Tony Marques
Re: eapol-pkt-drop when roaming from AP-105 to AP-124
Should not be.
What version of ArubaOS?
What type of client?
What type of encryption?
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
6.1.2.7, although upgrading to 6.1.3.7 this weekend. Lenovo laptop WPA2-AES
Do you observe this sometimes, all the time or this is the first time?
What wireless adapter and what is the driver date?
Seems like it is every time is roams to the AP-124. Adapter is an Intel Centrino Advanced-N 6205 with driver date of 8/3/2011 (version 14.2.0.10). Third party Wi-Fi management software has been removed and it is using Windows to manage Wi-Fi.
