Contributor I
enabling radio in AP-125
hi,
I am using Mobility Controller 3200XM.  And AP-125.  I am trying to create SSID in AP using the following commands.  Radio LED doesnot glow on AP-125.
(Aruba3200) (config) #wlan ssid-profile myssidprofile
(Aruba3200) (SSID Profile "myssidprofile") #essid myessid
(Aruba3200) (SSID Profile "myssidprofile") #opmode opensystem
(Aruba3200) (SSID Profile "myssidprofile") #exit
(Aruba3200) (config) #wlan virtual-ap myvirtualap
(Aruba3200) (Virtual AP profile "myvirtualap") #ssid-profile myssidprofile
(Aruba3200) (Virtual AP profile "myvirtualap") #vlan 1
(Aruba3200) (Virtual AP profile "myvirtualap") #exit
(Aruba3200) (config) #rf arm-profile myarmprofile
(Aruba3200) (Adaptive Radio Management (ARM) profile "myarmprofile") #assignment disable
(Aruba3200) (Adaptive Radio Management (ARM) profile "myarmprofile") #exit
(Aruba3200) (config) #rf dot11a-radio-profile mydot11aradioprofile
(Aruba3200) (802.11a radio profile "mydot11aradioprofile") #arm-profile myarmprofile
(Aruba3200) (802.11a radio profile "mydot11aradioprofile") #no high-throughput-enable
(Aruba3200) (802.11a radio profile "mydot11aradioprofile") #channel 48
(Aruba3200) (Virtual AP profile "myvirtualap") #allowed-band a
(Aruba3200) (config) #ap-name 6c:f3:7f:ce:60:a2
(Aruba3200) (AP name "6c:f3:7f:ce:60:a2") #virtual-ap myvirtualap
(Aruba3200) (AP name "6c:f3:7f:ce:60:a2") #dot11a-radio-profile mydot11aradioprofile
Please tell if I missed out something.
Thanks in advance.
-uv.
Re: enabling radio in AP-125
Type "show ap database" to see if there is a flag next to that access point, or if it even shows up.
Contributor I
hi,
This is what I got. It detects AP.
(Aruba3200) #show ap database
AP Database
Name               Group    AP Type  IP Address     Status  Flags  Switch IP
 Standby IP
6c:f3:7f:c7:4f:72  default  125      192.168.10.36  Down           192.168.10.1
 0.0.0.0
Flags: U = Unprovisioned; N = Duplicate name; G = No such group; L = Unlicensed
       I = Inactive; D = Dirty or no config; E = Regulatory Domain Mismatch
       X = Maintenance Mode; P = PPPoE AP; B = Built-in AP
       R = Remote AP; R- = Remote AP requires Auth; C = Cellular RAP;
       c = CERT-based RAP; 1 = 802.1x authenticated AP; 2 = Using IKE version 2
       u = Custom-Cert RAP; S = Standby-mode AP; J = USB cert at AP
       M = Mesh node; Y = Mesh Recovery
Total APs:1
uv.
Type "show  log system 50" to see if there is any information about that AP.
For now, your AP is not on that controller...
Contributor I
hi joseph,
I could see some license related stuff.
Mar 14 11:17:47 :311002:  <WARN> |AP 6c:f3:7f:c7:4f:72@192.168.10.36 sapd|  Rebo
oting: SAPD: Reboot requested by controller
Mar 14 11:17:48 :303086:  <ERRS> |AP 6c:f3:7f:c7:4f:72@192.168.10.36 nanny| Proc
ess Manager (nanny) shutting down - AP will reboot!
Mar 14 11:18:32 :303022:  <WARN> |AP 6c:f3:7f:c7:4f:72@192.168.10.36 nanny|  Reb
oot Reason: AP rebooted Mon Mar 14 11:17:48 PST 2016; SAPD: Reboot requested by
controller
Mar 14 11:18:54 :305038:  <WARN> |stm|  No available license for AP 6c:f3:7f:c7:
4f:72
Mar 14 11:27:48 :311002:  <WARN> |AP 6c:f3:7f:c7:4f:72@192.168.10.36 sapd|  Rebo
Mar 14 11:27:48 :303086:  <ERRS> |AP 6c:f3:7f:c7:4f:72@192.168.10.36 nanny| Proc
Mar 14 11:28:32 :303022:  <WARN> |AP 6c:f3:7f:c7:4f:72@192.168.10.36 nanny|  Reb
oot Reason: AP rebooted Mon Mar 14 11:27:49 PST 2016; SAPD: Reboot requested by
controller
Mar 14 11:28:54 :305038:  <WARN> |stm|  No available license for AP 6c:f3:7f:c7:
4f:72
Mar 14 11:37:55 :311002:  <WARN> |AP 6c:f3:7f:c7:4f:72@192.168.10.36 sapd|  Rebo
Mar 14 11:37:56 :303086:  <ERRS> |AP 6c:f3:7f:c7:4f:72@192.168.10.36 nanny| Proc
Mar 14 11:38:39 :303022:  <WARN> |AP 6c:f3:7f:c7:4f:72@192.168.10.36 nanny|  Reb
oot Reason: AP rebooted Mon Mar 14 11:37:56 PST 2016; SAPD: Reboot requested by
controller
Mar 14 11:39:01 :305038:  <WARN> |stm|  No available license for AP 6c:f3:7f:c7:
4f:72
Mar 14 11:47:55 :311002:  <WARN> |AP 6c:f3:7f:c7:4f:72@192.168.10.36 sapd|  Rebo
Mar 14 11:47:56 :303086:  <ERRS> |AP 6c:f3:7f:c7:4f:72@192.168.10.36 nanny| Proc
I searched google and got some more info.
(Aruba3200) #show ap license-usage
AP Licenses
Type                      Number
AP Licenses               0
Overall AP License Limit  0
AP Usage
Type             Count
Active CAPs      0
Standby CAPs     0
RAPs             0
Remote-node APs  0
Tunneled nodes   0
Total APs        0
Remaining AP Capacity
Type  Number
CAPs  0
RAPs  0
Can I somehow use the mobility controller and one Aruba AP without licenses.
thanks
uv.
No.  You need a license..
