filter broadcast multicast question
  • 1.  filter broadcast multicast question
    Posted Oct 30, 2012 09:04 PM
    Okay i got a client which has no idea if he is using multicast in his network... he has some cisco wireless ip phones...
    And well im not sure if i should activate it... well i  could to try but im not sure if these kind of thing use multicast
    For now i didnt have any issue with is becasue none of the clients were using multicast over the air....
    But my question is
    If the clietn is using mulitcast i cannot turn on this feature? or i can turn it on but i have to turn or something else to make it work?
    I want to activate this feature because the client got lot of problems with their wireless network and i got like a list of things im dong but this is one of the list...
    Anyone can help:)
  • 2.  RE: filter broadcast multicast question
    Posted Nov 02, 2012 01:08 PM
    Not sure I follow the question, but you can support multicast over the air, and we have a few additional capabilities in how we support multicase over the air, specifically we can support converting multicast to unicast over the air at a level specific to the number of multicast streams that have been subscribed to. Grab the user guide and look up the section on Multicast, and from there you can start to weigh your options as far as how and at what ratios you convert multicast to unicast, and when over that number it stays multicast.
  • 3.  RE: filter broadcast multicast question
    Posted Nov 02, 2012 01:11 PM
    Okay there is an option called Drop broadcast/multicast on the VAP
    What i want to know if that if i just can enable that if multicast is NOT userd on the air, let say im using ip phones or something that use mutlicast then i wont be able to use it? or  i can use it but i have to do something else to make it work?
  • 4.  RE: filter broadcast multicast question
    Posted Jan 11, 2013 01:56 AM
    Hello Nightshade1
    have you find any answer of this???
    Please let us know if you...
  • 5.  RE: filter broadcast multicast question
    Posted Jan 11, 2013 01:13 PM
    The wireless cisco phones require multicast , if you enable drop broadcast is going to impact your connection.
    You could enable the following:
    DMO
    Convert Broadcast ARP requests to unicast under the VAP
    IGMP under the voice VLAN
  • 6.  RE: filter broadcast multicast question
    Posted Jan 11, 2013 01:14 PM
    Meaning enabling drop broadcast will impact any connection that requires multicast to function
