Frequent Contributor I
first rap configuration
I would like to configurate a remote AP, but I can't.
Can I ask to write a step by step guide for this?
Here is a simple wlan base config and I would like to see a test ssid in my brach office.
interface 0/8
vlan 1
192.168.10.0/24
192.168.10.150 controller
vlan 100
192.168.100.1/24
SSID
test -- vlan 100
Thank you in advance for your reply.
Re: first rap configuration
I have attached an Aruba guide on how to deploy remote APs , you can pretty start on chapter and it should guide through the initial setup.
If you get stuck on anything let us know.
Vic
Thank you
Victor Fabian
Lead Mobility Architect @WEI
I meant to say chapter 2
Thank you
Victor Fabian
Thank you vfabian! I will try to configurate.
