gvrp
Is there a way to enable gvrp on aps (205h and 215)? I have 802.1x sending users to certain vlans (bridge mode). The only way it is working is for me to manually tag the ap switch port for the vlan. Would be awesome if gvrp could do this for me.
My setup
7210 in data center
300+ 205h / 215 in 5 locations
ArubaOS 6.4.3.8
Tom
Re: gvrp
what is gvrp?
The user VLAN for each SSID needs to be trunked to each access point in a distributed setup like Instant.
Re: gvrp
gvrp
http://h22208.www2.hpe.com/eginfolib/networking/docs/switches/RA/15-18/5998-8155_ra-2620_atmg/content/ch02.html
gvrp would do auto tagging so I would not have to manually do 300+ aps
Tom
Re: gvrp
Tom,
If you have 300+ APs, you should consider a controller, instead. You would only have to tag the VLANs on a single interface between the controller and a layer 3 switch..
Re: gvrp
I do have controller
7210 in data center
Dont follow this
I have all hp switching so will use their 802.1q commands
Ap 205h untagged vlan 110 (native vlan for the classroom the ap is in)
When a student logs in I want to drop them in vlan 72
When a teacher logs in I want to drop them in vlan 75
This works when I
vlan 72 tag port_of ap
vlan 75 tag port_of_ap
If the ap did gvrp, the switch would see vlan 72 traffic and auto tag the port.  Or, am I missing something?
Tom
Re: gvrp
So you have a single controller in the datacenter and all user traffic will be bridged to the local network through the AP, or will all user traffic be tunneled to the controller?
Re: gvrp
Bridged otherwise I would tag at the controller??/
Tom
Re: gvrp
I don't know anything about GVRP and maybe someone should chime in.
But from a design perspective:
If none of your APs tunnel any user traffic back to the controller, the design decision should be instead to have Instant AP clusters at those locations, instead of having to send back VLANs per site in a controller-based design....
Re: gvrp
Some will tunnel (guest).
I agree I should have been sold IAP versions. Don't see why any other version is sold. IAP can do them all (campus, rap, iap).
This is what I want to do. Looks like iap only???
http://community.arubanetworks.com/t5/Wired-Networks/Pre-provisioning-VLAN-in-MAS-using-GVRP/ta-p/166292
Tom
