Contributor II
have any one did a mesh between 2 MSRs with ANT-2x2-5314 for 3 Km distance?
Dears, Hvae any one tried to mesh on such a distance before and what is the expected data rates on 40 MHZ with clear LoS
Islam Zidan │ Professional Services Engineer | ACCP,ACMP,ACEAP,AWMP,CWSP,CWDP,CWNA,CCNP,HP ASE ,MCITP
If you Found My Post Helping you kindly Give KUDOS and if it solved your question Kindly hit Accept as a solution box.
Super Contributor I
Re: have any one did a mesh between 2 MSRs with ANT-2x2-5314 for 3 Km distance?
Are you looking to just do a bridge? If so you might want to look into the MST200.
ACDX #419 | ACMP |
Contributor II
I will give it a shoot and see what will happen but have you tried it before I have tried 1.5 km worked well like 117mb data rate but 3 km will be chalange
MST200 at HT40 should give you the attached plots (with clear LoS, no fresnel zone issues, etc). Follow the red line for HT40. If you need HT20, drop those rates by approx 50% (roughly). At 3km you should be around 70-80Mbps HT40, or around 35-40Mbps HT20.HT40 rate v range
Jerrod Howard
Contributor II
Thanks Man really add value I will check once I got the equipment and feed you back
Contributor II
One more thing now ANT 5614 is 60 degreee I belive 5314 will be more focused which may give better link quality
They are effectively the same (MST200 is 14dBi with 55deg horizontal and 13deg vertical; 5614 is 14dBi 60deg horizontal with 14deg vertical).
Jerrod Howard
is 5614 is the same as 5314!!
The 5314 is also a 14dBi antenna, but is 30deg x 30deg, the 4614 is a 14dBi antenna and is 60deg x 15deg.
Jerrod Howard
Contributor II
thats what I mean 30 Degree is more focused
