help
SORRY FOR THE NOISE BUT CAN I ASK U , IF I CAN MAKE MSR2000 WORK AS AN LAYER 2 ACCESS POINT ,
JUST CONNECT MY LAPTOP TO A LAN I USE RADIO 0 TO CONNECT MY LAPTOP I USE ETHERNET INTERFACE TO CONNECT TO THE LAN IT DOESNT WORK ,
AND HERE IS THE COMMANDS
:: #interface gigabit-ethernet 0
#ip add192.168.0.96/ 24 , this ip is in the same subnet of the lan
# no shut
#interface dot11radio 0
# bss 15
#ip add 192.168.216.1/24 ,,, and my laptop has a static ip 192.168.216.22/24
and all these interfaces directly connected ,,, but no internet access , plz help
