hi guys, i need your help, please help me!
Does the 3200 controller purge APs from the database after a dormancy period? If so, what is that period of time? Also, if I have whitelisted a RAP, I assume the controller will not add it to the AP databse until it has connected. Please confirm this for me.
I am trying to complete an inventory but I have a few different data sources and I need a little general inof.
Thanks in advance.
Re: hi guys, i need your help, please help me!
The 3200s do not purge APs from their database.  You can do it manually through the GUI for down access points.
The controller will not add it to the database until it has connected.
