hidden SSID issue with android
hii guyzz..........
I have controller 7210 with AOS 6.2.1.1,
I have two hidden SSIDs one with  802.1x authentication and one with wpa2-psk.
On android devices i am facing a issue, even after manually configuring the ssid device says "not in range" for both SSID,
sometimes it conects but most of the time just says "not in range".
I have checked with android 2.3.5, 4.0.2, 4.1.1.
With rukus AP with same configuration it works well, i checked that.
pls commnt............................
Re: hidden SSID issue with android
Is this only happening to the android devices ?
Is the android able to connect with same SSID while being broadcast ?
Do you have the local probe threshold set to a certain value?
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Are you using RFProtect?
Do you have AirWave? Check to see if those devices are being reported as a DoS attack.
Also, if you have a device to test with, try the following:
In the dialer type: *#0011#
Choose the Wi-Fi option in the service menu.
Turn the Wi-Fi power saving option to off.
See if you are able to connect.
Tim Cappalli | Aruba Security
not sure if it will help u:
thnx for reply..
issue is with android only and local probe threshold is 0db by default.
and it doesnt face issue when ssid being broadcasted..
