hidden node and channel interference
What will happen in the following scenarios
Two  Ap's which is nearly close to each other .
both nodes are 2.4 Ghz Devices
1 ) One  node is connected to  AP 'a' other one  AP 'b' in the same channel ,  both node's  RSSI nearly -50dBms  both can listen to each other
2  ) One  node is connected to  AP 'a' other one  AP 'b' in the same channel ,  both nodes  RSSI nearly -50dBms  both cannot  listen to each other
3) both node's are connected to the same ap  in the same channel and both node's RSSI nearly -50dBms both can listen to each other
4) both node's are connected to the same ap  in the same channel and both node's RSSI nearly -50dBms both cannot  listen to each other
3) both node's are connected to the same ap  in the different channel   both node's RSSI nearly -50dBms both can listen to each other
4) both node's are connected to the same ap  in the different channel   both node's RSSI nearly -50dBms both cannot  listen to each other
