high availability/fast failover question about SLAVE role
I have got a new Aruba 7005 to install as slave for the master. However I have a question that I couldn't find answer into the documentatio:
I have the MASTER and SLAVE that the see each other and the are able to work as expected, however into the SLAVE I don't have/see any AP configured. So, I was wondering if first I need to add the APs on the second controller and then configure as slave
Re: high availability/fast failover question about SLAVE role
Did you read the chapter here? http://www.arubanetworks.com/techdocs/ArubaOS_65x_WebHelp/Web_Help_Index.htm#ArubaFrameStyles/VRRP/HighAvOverView.htm?Highlight=Redundancy
It depends to which controller you are pointing your Aps to .
IF you have HA/FF you can define the controllers that will be part of your HA Group and under AP-Group > AP System Profile > you then point the AP to the main controller and the AP will use any of the other controllers in the list as backups .
To see if there's a standby tunnel created you can run the show ap database and you will see the "S" Flag which stands for Standby tunnel
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Here's a good article that explains how it works:
https://community.arubanetworks.com/t5/Controller-Based-WLANs/How-does-high-availability-fast-failover-feature-work-and-how-to/ta-p/177468
Thank you
Victor Fabian
So, this is the only part found about the AP related to HA config
"When the AP first connects to its active controller, the active controller provides the IP address of a standby controller, and the AP attempts to establish a tunnel to the standby controller. If an AP fails to connect to the first standby controller, the active controller selects a new standby controller for that AP, and the AP attempts to connect to that standby controller."
What does it mean? Do I have to reboot the AP after the MASTER/SLAVE is configured.
I'm finding extremelly difficult work with Aruba! I spent a lot of time trying to understandthe documentation as it is always to much generic and dispersive.
Thanks anyway for your help
You do not have to reboot the AP. When the AP finds that first controller, it gets its instructions from the first controller it finds.
Thanks for your reply. How can I verify if the APs/SLAVE have found each other?
There is no "slave".  Do you have your controllers setup as a master/local?
Yes,
They are MASTER and LOCAL
You type "show ap database" on the master controller.  The "standby ip" column should list what is the standby controller ip addres that AP is pointing to.  0.0.0.0 means that no ha is configured.
