high interference and low speed
I am newbie to wireless and I need assistance with 2 access points that have high interference, high channel utilization, and low speed. I have disabled 3 out of 6 SSIDs that are not needed from them, and from the neighboring access points. What else can I do? Please see attachment.
Re: high interference and low speed
I'd recommend looking into reducing your Min-tx-power and the max-tx-power as your cafe AP can "see" at least 15 other APs on the same channel. Also it can see 5 APs with a SNR of over 25 which isn't good.
Some reading about power levels.
