high packet loss after enabling 802.11n
Hi, we have just enabled HT on the 3200 controllers, clients are experiencing high packet loss, was fine on standard g connection.  It's a fairly dense deployment of AP93's on 2.4ghz any ideas what could be causing the loss?
thanks
Re: high packet loss after enabling 802.11n
Exactly what parameter did you enable?
Are these "N" clients?
Are they using encryption?
sorry for the confusion the clients were using WPA-TKIP we updated Group policy and SSID to allow WPA-TKIP & WPA-AES.  The clients now connect at speeds varying between 1-130mbs but there seems to be a lot of packet loss
Clients that use WPA-TKIP have a maximum association rate of 54m.  AES would give you "N" speeds, but group policy can only configure one encryption type.  How do you configure two?
