how can we connect 2 sites using Wired AP ?
hey there
i have site A and site B , A is ocnnected directly to the Backhaul , B has no backhaul and its conencted to site A via outdoor AP , i used wirted Ap profile to configure on eht0 site A`s Vlan .
Site B came up on a testing controller and got configurations from siite A , once i did it on life controller it didnt work .
Please advice .
Digram is attached ..
Re: how can we connect 2 sites using Wired AP ?
You need to configure it as a mesh portal/point
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Hi victor
Its already configured , mesh portal on site A and point on site B .
Is your switch on the other end configured with a trunk or access port?
Thank you
Victor Fabian
Aruba
Is the Site B AP (mesh point) connecting to Site A (mesh portal) when at the remote site?    You say it came up on testing controller, but not live controller....so I wasn't sure if you are even getting it to come up.
Did you provision the mesh point against the live controller with its mesh cluster profile while it was at Site A?   If your test controller is not part of the same master/local topology, this may be an issue.
AMFX | ACCX | ACDX | ACMX
