Frequent Contributor II
how long should I run debug for?
I want to troubleshoot a couple of AP 224s that are reportedly going down every so often, I've run:
logging level debugging ap-debug <mac address> process approc
Is it safe to leave that running overnight? I'm just worried about how resource hungry it is.
Re: how long should I run debug for?
You should keep an eye on the cpu of the controller to determine that.  Typically it is fine.
Great, thanks, I'll keep an eye on it
