how many access point can IAP-103-RW Access Point managed?
[ Edited ]
Dear Gurus, May I know how many access points that an IAP-103-RW virtual controller can managed?
MVP
Re: how many access point can IAP-103-RW Access Point managed?
That question is not as simple to answer as you might think. There is no official limit, tested cluster size is 128 APs. There are probably other parameters, like network design, that can reduce performance in larger clusters.
Please check the Aruba Instant VRD for more information; or better work with your Aruba partner or local sales team to get to a proper design of your wireless network.
