- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
03-23-2016 06:52 AM
hi everyone i'm having a trouble adding AP on controller, can you please help me,
yesterday i have added some AP, but i those ap are not up now and new ap also not able to add
i can ping all AP from controller those previous AP,
but i'm missing somewhere
can you please help to
i would like to invite anyone teamviewer plz, i have been trying to make it happen since yesterday still same
teamviewer ID 502 551 801
PWD: 5932
i will be awainting
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
03-23-2016 06:57 AM
If used, did you purge them?
Do you have CPSEC enabled?
How are you doing controller discovery?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
Re: how to add Access point to controller
03-23-2016 07:04 AM
it is brand new AP 205,
i have total 150 AP need to add on controller. but unable to do so
could you please try to connect team viewer plz
thanks,
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
03-23-2016 07:30 AM
This is not really a suport forum for people to jump on to help, if they can great, but if you need something fast, I would open a TAC case. You still hadn't answered the other questions above (AP discovery, CPSec on or off, etc). My recommendation would be to open a TAC case and work with them to assist you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
03-23-2016 08:27 AM
PWD: 5932
i will be awainting
I would SSH into the controller and type "show audit-trail" to see if anything was changed between yesterday and today", so that you can perhaps get an idea what is wrong...
Colin Joseph
Aruba Customer Engineering
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
03-26-2016 02:41 AM - edited 03-26-2016 02:42 AM
thanks Colin Joseph
now i have added 119 AP, i still have to add 31 more, i will go site later on then will double check.
but the problem i was experiencing the AP is too much heat, even if you touch by your hand you feel very hot.
is there any solution to reduce heat on AP?
thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
03-26-2016 03:37 AM
You cannot reduce the heat on an access point, no.
Colin Joseph
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
03-27-2016 12:00 AM
thanks Colin Joseph
but it seems not normal case, it is too much heat, are you sure we can't fine tune to reduce heat
thanks!!
Regard
Mr. Tej Bahadur
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
03-27-2016 12:51 AM
It's a common concern as they do get warm, the back of the AP is designed to be a heat sink (it's a very common question). However, it's well within spec. If you want to get an IR camera to shoot a picture and post it, we can tell you if it's within spec. I don't recall the temp off the top of my head at 2AM, but I can find out on Monday.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
