Frequent Contributor I
how to apply different bandwidth on users configured in the same profile ??? Help
[ Edited ]
I want to apply the different bandwidth limit on those users which are connected to the same ssid as well as configured in the ssid aaa profile ????
kindly help me in this regard.
MVP
Re: how to apply different bandwidth on users in profile ??? Help
If u now the user mac - Just build a 2nd role - and use user devertion rules. like i teach u .
have a lovley day.
Frequent Contributor II
Re: how to apply different bandwidth on users configured in the same profile ??? Help
If you want this to be applied to USERS and not CLIENTS. you can for example make a group in AD for those who will have different bandwidth. Then you can set up your NPS and Server Derivation rules so that those users get the different role.
This will also be easier to administrate in the long run as you only have to give a user membership in the group in stead of entering/deleting  MAC addresses. :)
-ACMX #352-
Remember to Kudo if a post helped you! || Problem Solved? Click "Accept as Solution" in a post!
