how to block the system accessing another system in same aruba wlc wifi network
[ Edited ]
This is a test case as we are planing to deploy the new wifi setup and i want know like blocking the 1 system accessing another system in same subnet or vlan like ping data transfer etc.exampl aruba stateful firewall deny local routing/ deny inter user bridging.
Re: how to block the system accessing another system in same aruba wlc wifi network
