Frequent Contributor I
how to configure DHCP on controller
Hi
May i check how does DHCP work on the controller as apparantly am getting the feedback that the DHCP address am trying to set is the same as VLAN 1.
Re: how to configure DHCP on controller
What is the exact error?  If you have DHCP configured it must be in the subnet of a VLAN configured on the controller to work.  If it overlaps, you might get an error.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
70051.jpgip address of the standalone controller is 192.168.50.18/23
I would just give the controller a dummy ip address at the startup wizard, and don't configure anything major.  There could be some bugs with the startup wizard.
When you reboot and have the full configuration GUI, you should be able to configure everything more easily.
