how to connect AP274 to outdoor antennas
Re: how to connect AP274 to outdoor antennas
https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Entry
Id/279/Default.aspx
Tim Cappalli | Aruba Security
Another good link/document to use
http://www.arubanetworks.com/assets/og/OG_AP-270Series.pdf
Jerrod Howard
I want to connect a 3x3-D100 antenna (dual-band) to an AP274 but it seems there is no documentation that specify exactly how to connect it (even in the links sent in the previous posts).
The antenna has only 3 connectors (-45°, 45°, V) and the AP has 3 connectors per band (6 connectors), so how to connect it ??
I didn't find any documentation about this connection (AP installation guide, antenna installation guide, etc.)
Thank you for replies...
Similar setup:
http://community.arubanetworks.com/t5/Wireless-Access/Aruba-Outdoor-AP-274-ANT-3x3-D608-Antennas/td-p/188756
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Thank you Victor for your reply ;)
