You can:
1. Add the same mesh profiles to both AP-Groups
2. When you provision access points, you just provision them as a Mesh Port or Mesh Portal.
3. *IMPORTANT* when you change mesh profile information, you have to reprovision access points for them to get the new profile information. That means provisioning the access points on the far side first, so that they do not get cut off by the change...
