Frequent Contributor II
how to delete a port-channel
Is there a way to delete a port-channel that is no longer used.
I tried "no interface port-channel 1" from the cli with no luck and there does not seem to be any obvious method in the GUI.
Thanks in advance.
Re: how to delete a port-channel
What error did you get when you can that command?
Tim
Tim Cappalli | Aruba Security
(config) # no interface port-channel 1
% invalid input detected at ' ^ ' marker.
The '^' is displayed beneeth the '1'
Cheers
From the Controller Web Interface you can disable the port-channel clicking on the ports belonging to the port-channel and confirm it doing Apply.
Massimo
[If you found my post helpful, please give kudos]
Massimo Gallina
Telecommunications engineer - ACMP2013
I understand that this will disable the port-channel.
Same as typing Shutdown from the CLI
What I am trying to do is remove the port-channel from my config completely.
in the cisco world its as simple as
no interface port-channel 1 but Aruba does not seem to have an equivelant command.
Massimo
(OCDSB-M1-Pri) #show running-config | include port-channel
Building Configuration...
interface port-channel 0
(OCDSB-M1-Pri) #show interface port-channel 0
Port-Channel 0 is administratively up
Hardware is Port-Channel, address is 00:1A:1E:01:7F:48 (bia 00:1A:1E:01:7F:48)
Description: Link Aggregate
Spanning Tree is disabled
Switchport priority: 0
Member port:
GE 0/0/0, Admin is up, line protocol is up
GE 0/0/1, Admin is up, line protocol is up
Last clearing of "show interface" counters 0 day 18 hr 7 min 18 sec
link status last changed 0 day 18 hr 5 min 6 sec
83297 packets input, 6453179 bytes
Received 78116 broadcasts, 0 runts, 0 giants, 0 throttles
0 input error bytes, 0 CRC, 0 frame
69492 multicast, 5181 unicast
33909 packets output, 4355603 bytes
0 output errors bytes, 0 deferred
0 collisions, 0 late collisions, 0 throttles
Port-Channel 0 is TRUSTED
(OCDSB-M1-Pri) #show interface port-channel 1
Port-Channel 1 is administratively down
Member port:
Last clearing of "show interface" counters 0 day 18 hr 7 min 38 sec
link status last changed 0 day 18 hr 7 min 38 sec
0 packets input, 0 bytes
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 multicast, 0 unicast
0 packets output, 0 bytes
Port-Channel 1 is TRUSTED
cappalli wrote:
That command is definitely valid. Can you run:
show runn | include port-channel
Tim
There is no way to delete a port channel.  If you make it untrusted (the default confguration of a port channel) and no interfaces are assigned to it, it will go away.
On top of that, I've found I have to remove all commands that make the port-channel interface differ from the default, e.g.:
 int port-channel 1
  no trusted
  no switchport mode
  no switchport trunk allowed vlan
Probably you have to do other things too (like "no description").  However, once it's all back to the "default" then it disappears.
