Hi guys,
I'm trying to setup IAP Mesh, to do that i need to disable extended ssid configure.
I did that, but when i reboot the IAP cluster, i notice that even i disabled extended ssid configure, but it still "enable" somehow. Could you please help me on this?
IAP-Master# show swarm state
AP Swarm State :swarm_config_sync_complete
mesh ldart State :suspending
Config in flash :yes
factory SSID in flash :no
extended-ssid configured :no
extended-ssid active :yes
Config load cnt :1
VC Channel index :1
IDS Client Gateway Detect :yes
IAP-Master#
!!!!!!! below is show running configure !!!!!!!!!
IAP-Master# show running-config
version 6.4.2.0-4.1.3
virtual-controller-country SG
virtual-controller-key 7cb3a37401c4b58e7d2658909293421bae74ec11eaa7104a76
name VC
virtual-controller-ip 16.178.233.63
terminal-access
ntp-server 192.168.1.10
clock timezone Singapore 08 00
rf-band all
allow-new-aps
allowed-ap 84:d4:7e:c6:1a:16
allowed-ap 84:d4:7e:c6:1a:a2
arm
wide-bands all
80mhz-support
a-channels 36,40,44,48,36+,44+,36E
min-tx-power 3
max-tx-power 3
band-steering-mode prefer-5ghz
air-time-fairness-mode fair-access
client-aware
scanning
syslog-level warn ap-debug
syslog-level warn network
syslog-level warn security
syslog-level warn system
syslog-level warn user
syslog-level warn user-debug
syslog-level warn wireless
mgmt-user admin d47900ac330b2d8943a8064b472e7780
wlan access-rule default_wired_port_profile
index 0
rule any any match any any any permit
wlan access-rule wired-instant
index 1
rule masterip 0.0.0.0 match tcp 80 80 permit
rule masterip 0.0.0.0 match tcp 4343 4343 permit
rule any any match udp 67 68 permit
rule any any match udp 53 53 permit
wlan access-rule mest-p2p
index 2
wlan ssid-profile mest-p2p
enable
index 0
type employee
essid mest-p2p
wpa-passphrase 363aafcf36ee54e0dac513467f1494a667f94b17e569a048
opmode wpa2-psk-aes
max-authentication-failures 0
auth-server InternalServer
rf-band all
captive-portal disable
dtim-period 1
inactivity-timeout 1000
broadcast-filter arp
dmo-channel-utilization-threshold 90
local-probe-req-thresh 0
max-clients-threshold 64
auth-survivability cache-time-out 24
wlan external-captive-portal
server localhost
port 80
url "/"
auth-text "Authenticated"
auto-whitelist-disable
https
blacklist-time 3600
auth-failure-blacklist-time 3600
ids
wireless-containment none
wired-port-profile wired-instant
switchport-mode access
allowed-vlan all
native-vlan guest
no shutdown
access-rule-name wired-instant
speed auto
duplex auto
no poe
type guest
no dot1x
wired-port-profile default_wired_port_profile
switchport-mode trunk
allowed-vlan all
native-vlan 1
shutdown
access-rule-name default_wired_port_profile
speed auto
duplex full
no poe
type employee
no dot1x
enet0-port-profile default_wired_port_profile
uplink
preemption
enforce none
failover-internet-pkt-lost-cnt 10
failover-internet-pkt-send-freq 30
failover-vpn-timeout 180
airgroup
disable
airgroupservice airplay
disable
description AirPlay
airgroupservice airprint
disable
description AirPrint
