how to down a radio on an ap
I need to know if there is a way, by cli or GUI to put down temporaly a radio on an ap.
Re: how to down a radio on an ap
In the AP Configuration --> AP Specific screen on the UI, you can assign a radio profile to be an Air Monitor effectively "downing" the access for users on that band for a particular AP within a group.
Seth R. Fiermonti
Consulting Systems Engineer - ACCX, ACDX, ACMX
Email: seth@hpe.com
If you found my post helpful, please give kudos
