how to know remote ap clients monthly
i'm new, i should  reportd every month  my boss about , but i don't know how to cheak clients that remote
ap monthly。
Re: how to know remote ap clients monthly
Do you have AirWave?
Tim Cappalli | Aruba Security
yes  there is a airwave server , but i don't konw how to view that
can anyone help me ?   V_V
Spoiler
It's not clear what you are needing. If you have AirWave, open the User Guide from the Documentation page, and look up reports/reporting. It should show you how to generate reports based on users active, APs up or down, etc. You will have to learn how to build your reports and will likely be some trial and error.
Jerrod Howard
First of all, i'm sorry for my bad English .
Thank you  for your answer ,
I'll  do as you way  .
Thank you bro  ^_^!!
