how to verify WMM marking on controller
  • 1.  how to verify WMM marking on controller
    Posted Aug 26, 2014 02:24 PM
    I would be happy if someone could clarify below queries :
    We have configured WMM on controller for specific SSID (Voice SSID for spectralink phones) and configured WMM DSCP mapping for voice 46 and for video 40 ...
    and configured end to end QoS in LAN
    query 1 : how do i verify that marking is been trusted on controller ?
    Iquery 2 :  came across below show command output  and concern about mapping
    show datapath session table | include 162.61.158.69
    161.18.21 172.16.62.1 17 5060 53800 0/0 6 0 1 1/0 1a 0 0 FYI
    172.16.62.1 172.16.18.21 17 32217 2241 0/0 0 0 1 1/0 15 0 0 FC
    172.16.62.1 172.16.18.21 17 17081 2255 0/0 0 0 0 sysmsg 107 8 1 120 FRHCV
    172.16.62.1 172.16.18.21 17 17080 2254 0/0 0 0 0 vlan 50 8 452 90400 FHCV
    172.16.18.21 172.16.62.1 17 5060 5060 0/0 6 40 0 tunnel 186 7 1 640 FTCI
    172.16.62.1 172.16.18.21 17 5060 5060 0/0 6 40 0 tunnel 186 7 0 0 FYI
    172.16.18.21 172.16.62.1 17 2241 32217 0/0 0 0 1 1/0 16 0 0 FY
    172.16.62.1 172.16.18.21 17 53800 5060 0/0 6 0 0 1/0 1b 2 1433 FCI
    172.16.18.21 172.16.62.1 17 2254 17080 0/0 0 0 0 vlan 50 9 501 100200 FHCV
    172.16.18.21 172.16.62.1 17 2255 17081 0/0 0 0 0 sysmsg 107 9 2 240 FRHCV
    172.16.18.21 224.0.1.116 2 6 6 0/0 0 0 0 tunnel 531 168c 373 11936 FTCI
    As I understood from above output is , WMM 6 is been mapped with 40 but i am expecting 6 should map to 46 ....
    what could be the issue ? or am i  looking in output wrong way ?
  • 2.  RE: how to verify WMM marking on controller
    Posted Aug 26, 2014 05:13 PM
    Have you done a packet capture and see hows the client sending this marking ?
    If you want re-mark the frame at the controller firewall level or overwrite thw WMM at the SSID level ?
  • 3.  RE: how to verify WMM marking on controller
    Posted Aug 27, 2014 06:49 AM
    Well, I have not done packet cappture yet however i could see hits on switch side ( core switch - AP connected port with show command )
    show mls qos interface < interface ID > statistics
    please find below output of show wlan ssid-profile
    show wlan ssid-profile < abcVoice >
    SSID Profile "abcVoice"
    Parameter                                         Value
    SSID enable                                       Enabled
    ESSID                                             ABCD
    Encryption                                        wpa2-psk-aes
    DTIM Interval                                     2 beacon periods
    802.11a Basic Rates                               6 12 24
    802.11a Transmit Rates                            6 9 12 18 24 36 48 54
    802.11g Basic Rates                               1 2
    802.11g Transmit Rates                            1 2 5 6 9 11 12 18 24 36 48 54
    Station Ageout Time                               1000 sec
    Max Transmit Attempts                             3
    RTS Threshold                                     2333 bytes
    Short Preamble                                    Enabled
    Max Associations                                  64
    Wireless Multimedia (WMM)                         Enabled
    Wireless Multimedia U-APSD (WMM-UAPSD) Powersave  Enabled
    WMM TSPEC Min Inactivity Interval                 0 msec
    Override DSCP mappings for WMM clients            Disabled
    DSCP mapping for WMM voice AC                     46
    DSCP mapping for WMM video AC                     40
    DSCP mapping for WMM best-effort AC               0
    DSCP mapping for WMM background AC                0
    Multiple Tx Replay Counters                       Disabled
    Hide SSID                                         Disabled
    Deny_Broadcast Probes                             Disabled
    Local Probe Request Threshold (dB)                0
    Disable Probe Retry                               Enabled
    Battery Boost                                     Disabled
    WEP Key 1                                         N/A
    WEP Key 2                                         N/A
    WEP Key 3                                         N/A
    WEP Key 4                                         N/A
    WEP Transmit Key Index                            1
    WPA Hexkey                                        N/A
    WPA Passphrase                                    ********
    Maximum Transmit Failures                         25
    EDCA Parameters Station profile                   N/A
    EDCA Parameters AP profile                        N/A
    BC/MC Rate Optimization                           Disabled
    Rate Optimization for delivering EAPOL frames     Disabled
    Strict Spectralink Voice Protocol (SVP)           Disabled
    High-throughput SSID Profile                      VOice HT
    802.11g Beacon Rate                               default
    802.11a Beacon Rate                               default
    Advertise QBSS Load IE                            Disabled
    Advertise Location Info                           Disabled
    Advertise AP Name                                 Disabled
    Enforce user vlan for open stations               Disabled
    (Aruba_controller) #show rights user-voice
    Derived Role = 'voice'
     Up BW:No Limit   Down BW:No Limit
     L2TP Pool = default-l2tp-pool
     PPTP Pool = default-pptp-pool
     Periodic reauthentication: Disabled
     ACL Number = 63/0
     Max Sessions = 65535
    access-list List
    Position  Name        Type     Location
    1         sip-acl     session
    2         noe-acl     session
    3         svp-acl     session
    4         vocera-acl  session
    5         skinny-acl  session
    6         h323-acl    session
    7         dhcp-acl    session
    8         tftp-acl    session
    9         dns-acl     session
    10        icmp-acl    session
    sip-acl
    Priority  Source  Destination  Service      Action  TimeRange  Log  Expired  Queue  TOS  8021P  Blacklist  Mirror  DisScan  ClassifyMedia  IPv4/6
    1         any     any          svc-sip-udp  permit                           High                                                          4
    2         any     any          svc-sip-tcp  permit                           High                                                          4
    noe-acl
    1         any     any          svc-noe  permit                           High                                                          4
    svp-acl
    1         any     any          svc-svp  permit                           High                                                          4
    2         user    224.0.1.116  any      permit                           Low                                                           4
    vocera-acl
    1         any     any          svc-vocera  permit                           High                                                          4
    skinny-acl
    1         any     any          svc-sccp  permit                           High                                                          4
    h323-acl
    1         any     any          svc-h323-tcp  permit                           High                                                          4
    2         any     any          svc-h323-udp  permit                           High                                                          4
    dhcp-acl
    1         any     any          svc-dhcp  permit                           Low                                                           4
    tftp-acl
    1         any     any          svc-tftp  permit                           Low                                                           4
    dns-acl
    1         any     any          svc-dns  permit                           Low                                                           4
    icmp-acl
    1         any     any          svc-icmp  permit                           Low                                                           4
    Expired Policies (due to time constraints) = 0
  • 4.  RE: how to verify WMM marking on controller
    Posted Sep 02, 2014 02:06 AM
    Hi ,
    Can anybody look into this and let me know the right approach for this query to resolve or get right options to troubleshoot ?
  • 5.  RE: how to verify WMM marking on controller
    Posted May 14, 2015 01:43 PM
    Victor,
    I am working on a project and appear to be in the same situation you were in previously.  Were you able to find an answer to your question?
    One command I was given is "show ap debug client-stats", but the numbers for the WMM entries, which I assume to represent number of frames is significantly lower than the actual number of frames transmitted, and a large number of frames show as Rx BE, despite confirming (via wireless captures) nearly all WMM marked frames are set to 6 (Video).
  • 6.  RE: how to verify WMM marking on controller
    can you share the SSID profile configuration and the user role details:
    show wlan ssid-profile <Name-of-Profile>
    show rights <Name-of-User-Role>
