i am not able to convert ARUBA IAP205 to campus AP. giving error retrieve image failed, please help
during conversion i am getting below eerror from logs, full log file is attached. due to this i am not able to view this AP in controller\
show log upgrade
----------Download log start----------
Executing '/aruba/bin/download_image_swarm ac-ftp://192.168.254.210/armv7ns.ari --no-proxy X-Ap-Info:CM0098113,ac:a3:1e:c2:a1:5c,AP-205'
fetching ('/usr/sbin/wget -T 120 -t 3 --no-proxy --header=X-Ap-Info:CM0098113,ac:a3:1e:c2:a1:5c,AP-205 -a /tmp/download_url_log ftp://sap:x@192.168.254.210/armv7ns.ari')
--11:05:33--  ftp://sap:*password*@192.168.254.210/armv7ns.ari
           => `armv7ns.ari'
Connecting to 192.168.254.210:21... connected.
Logging in as sap ... Logged in!
==> SYST ... done.    ==> PWD ... done.
==> TYPE I ... done.  ==> CWD not needed.
==> PASV ... done.    ==> RETR armv7ns.ari ...
No such file `armv7ns.ari'.
Error: failed to retrieve image
cleaning up
done
Re: i am not able to convert ARUBA IAP205 to campus AP. giving error retrieve image failed, please h
What code is your controller running?
Tim Cappalli | Aruba Security
please find below
Name: Aruba Operating System Software. Model: Aruba3200 Version: 6.3.1.2 Compiled: 2013-12-18 at 16:43:23 PST (build 41362) by p4build
Frequent Contributor II
Hi
To convert your IAP-205 to a campusAP, your controller needs atleast to be on version 6.4.1.
Seems like you have a 3200, this will be problematic, as this controller does not have a large enough flash to support the newest code base.
You will either have to switch to å newer controller or buy a upgrade kit for this 3200, making it a 3200XM
Roar
You'll need AOS 6.4 for the 205 and 215.
thanks for that information, but we recently purchased this Controller and upgrade or replacing controller would not be an option for us. is there a way i can convert this IAP 205 this time atleast for next time i can purchase only normal AP's instead.
No
Moderator
hi Tabrez Goilka
if you just purchased it, you are entitled to software upgrades for 90 days per the standard s/w warranty. At any rate, for any AP2xx, you really want to be on 6.4.2.3 software.
As Tim notes, there is no way to make this 205 talk to anything other than 6.4.x, this is detailed in the AP product matrix available at http://www.arubanetworks.com/pdf/products/MAT_AP.pdf
regards
-jeff
thank you everyone for valuable information, however can i know which APs are compatible with this controller. and whether i can somehow upgrade controller to 6.4
Hi
The available AP's supported by your Aruba 3200 is as follows
As i wrote earlier, you could upgrade your Aruba 3200 controller to the latest 6.4.2.3, but as this device don't have enough flash memory, you will have to buy a upgrade kit.
Your device as for now is unable to be upgraded to 6.4.
Roar Fossen
