Frequent Contributor I
iAP Authenticated Captive Portal - login problem
Hi All
Strange problem when I have a new iAP cluster set for Guest Portal using Internal Authentication.
On a Laptop connecting to SSID and browsing brings up the Portal and login with redirect works correctly.
However when connecting my Android to the same SSID the Portal Automatically opens up, entering auth credentials it appears to stall for a while and then the login page reloads again - it continues to do so until I choose the option to "stay connected" and the open a browser wher the login then works.
I have not tested his on Apple as yet.
