MVP
iAP Templates using custom variables
This is a really cool addtion to the process - Thanks!
I get using %if custom = such and such%, but what I find is that I'd rather do more interesting logic.
Is there a NOT operator?
I've tried !=, <>, and NOT to no avail.
--Matthew
--Matthew
if I've helped, please give kudos
if I've provided a solution, please mark the solution so others can find it
Moderator
Re: iAP Templates using custom variables
Glad you like the feature.  This is the kind of feedback that really helps improve the product.  We currently do not have a 'NOT' operator, but please file it into the Ideas Portal on the support site.  Can you also provide some use cases?
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
MVP
We are replacing an existing (bad) WLAN product, but don't want to have both hot at the same time on the same SSID.
I want use custom_variable_2 to indicate variation from normal -- my preference is "Install" and blank.
So what I'm actually looking for is a test for blankness.
%if %custom_variable_2%=Install%
set dummy SSID
put radios in spectrum monitor mode
etc.
%endif%
%if custom_variable_2%NOT=Install%
do normal stuff
%endif%
I'm finding out that the synatx I'm using above isn't actually working.  Is it possible to test the variable for a specific string, or is it just a test of filled or not filled?
--Matthew
--Matthew
Moderator
Templates only test the existence or not of a variable on the device's variable listing.  It's not testing the content of the variables.
Rob Gin
MVP
Then I think I'll just head on over to the feature request page...
--Matthew
[ Edited ]
Hi msabin.
Did you ever get this to work, either with a feature upgrade or a workaround?
Is it possible to check if a field is NULL?
what i am trying to achieve is setting bandwidth limits as per a custom_variable
I have got the following:
 %if custom_variable_1%
 bandwidth-limit %custom_variable_1%
 %endif%
bandwidth-limit 2048
This appears to work, but has the side effect of causing an error in the config
Apologies for resurrecting an old post
TIA
G
MVP
I use that syntax for 7 or 8 variables now, all seem to work fine and I don't have any errors in the config reported.
The answer was that %if custom_variable_1% is essentially testing for NULL and if NULL then the if returns negative and the line is skipped.
What version of iAP/Airwave are you on, and what error are you getting.
--Matthew
Hi Matthew,
We are on AMP 7.7.13 and iAP 6.4.2.0.
When looking at the config, it shows the 2 bandwidth lines as such
Desired   bandwidth-limit 2048
          bandwidth-limit 768
Looking at the VC and the line shows
Configuration:    Error (Configuration contains invalid commands)
running a repair doesnt seem to resolve the issue.  I am 99.999% sure its not anything else in the config as if i remove the logic and revert back to
 %endif%
The error doesnt appear, making me think that the rest of the config is OK, and its this bit causing the issue.
 TIA
G
MVP
Yeah, I ran into the same behavior.
My solution was to dedicate a variable to that valueand set it for all locations.
We enter the "default" or "normal" value at all sites, then change it for those which need a variation.
--Matthew
Hi Matthew,
Glad its not just me :)
What method did you use to set all of them as a "default"?
Did you use the template to set the default limit then manually change the ones that required a different limit?
TIA
G
