iPad 2 Issues
Hi I'm new to this forum.
We've recently deployed an Aruba 6000 with S111 controllers and AP 105s. We are seeing issues with iPad 2. Once the device auto locks and goes to sleep when it is unlocked it cannot see any wireless networks. The only way to get the wireless working again is to do a full reboot. Has anyone else seen this? If so is there a fix or workaround?
Re: iPad 2 Issues
Welcome to Airheads Social!
Yes, many of us have seen these issues. It seems to be intermittent. It seems to be an Apple issue, as it happens to my iPad 1 regardless of what wireless vendor it is looking for.
Is your iPad running 5.0.1? That seems to have helped mine a little bit.
Zach
Zach Jennings
MVP
Re: iPad 2 Issues
that weird... i got arubas 3200 on a client and 3400 on a client both got ipads and they have not told me anything about any issue with it...
What version are you using on your aruba controller?
Alternetworks Corp
Re: iPad 2 Issues
Hi Zach,
Unfortunately it's not just me who's affected, the iPads are used by quite a few senior people at our organisation and I'm getting pressure to sort it out!
I've updated my firmware and will see how it performs.
James
Re: iPad 2 Issues
We're on version 6.1.2.3. We haven't had reports of iPad 1 issues just 2
MVP
Re: iPad 2 Issues
iwill test in my lab next week as we got ipad 2 also for testing...  because  that would be an issue for us also...
But like i isad thats weird that none of our clients  have reported anything... what im not sure if they got ipad1... which woulld seems to be the thing...
Alternetworks Corp
Re: iPad 2 Issues
Another thing you could try is putting your iPad in debug mode and simulate the failure. I still truely believe this issue is an iPad issue, as when mine does it, no SSID will show up at all. Even if I am in the car, and my phone sees 10 SSID. Anyhow, here is how to put your iPad in debug mode on the controller:
Basic Troubleshooting
1. Put your device in debug logging on the controller: conf t, logging level debugging user-debug your-device-mac
2. Simulate the failure
3. Now look at the logs: show log user-debug all | include your-mac-address
Zach
Zach Jennings
Moderator
Re: iPad 2 Issues
If you are using an Open SSID with Captive Portal enabled, be aware of the Apple Captive Network Assistant that is implemented in iOS devices such as iPhone and iPad. Here is a knowledge base article on this feature.
Re: iPad 2 Issues
I think you are probably right and the symptoms you describe are exactly what we see, but it never happens at home, I think it may be to do with the dual band radios.
I'll try the debug on Monday when I'm back in the office.
James
Re: iPad 2 Issues
Thanks, it'll be interesting to see if you find anything
James
