Contributor I
iPhone Roaming issues
We have a site with a 651 controller (v5.0.4.1) with three ap-125s. The users there are using an Apple Airplay (wifi) server and iPhones (v5.0.1) as clients. The wifi SSID is using WPA2-psk.
The users are noticing that when they are roaming with their iPhones, there is a noticeable "hiccup" when switching from one AP to another. When stationary, the users do not experience any interruption of service.
Any suggestions for eliminating / /smoothing out the roaming between APs for iPhone (any Apple) clients?
Contributor II
Re: iPhone Roaming issues
Vinson,
Check these two threads out, they should be helpful.    Most likely poor or lack of OKC support on the device is causing the attempt to re-use keys that the client hasn't cached.      Disabling OKC on the dot1x profile and enabling PMKID validation should improve roaming significantly.
http://community.arubanetworks.com/t5/Mobile-Device-Configuration-and/Let-s-Go-Roam/td-p/17444
http://community.arubanetworks.com/t5/Mobile-Device-Configuration-and/MAC-WLAN-Client-quot-Nuances-quot/td-p/1461
