iap-135 eth1 connected to a printer
quick question
iap-135 powered by a poe injector (not poe+).
eth0 connected to a DSL modem
no link light on the printer or a laptop.
please tell me poe+ is not required for the 2nd port to work?
Pasquale Monardo | Senior Network Solutions Consultant
ACDX #420 | ACCA
[If you found my post helpful, please give kudos!]
Re: iap-135 eth1 connected to a printer
Yes it is or power adapter
Thank you
Victor Fabian
Lead Mobility Architect @WEI
actually quite interesting found this article
http://community.arubanetworks.com/t5/Controller-less-WLANs/Why-does-the-ethernet-1-port-of-IAP-134-135-do-not-turn-active/ta-p/175344
but when you upgrade to 4.1.1.0 the port works without POE+. Just tested it
interesting...
ACDX #420 | ACCA
Nice!!, good to know
Thank you
Victor Fabian
crazy.
ACDX #420 | ACCA
