Contributor I
if I check drop multicast and Broadcast trraficc will it affect voice over WLAN?
Re: if I check drop multicast and Broadcast trraficc will it affect voice over WLAN?
If you're using AOS 6.4.1 or greater and voice clients are subscribed to a multicast group, then multicast voice should continue to work.
You would need to enable IGMP proxy though.
Tim Cappalli | Aruba Security
