Occasional Contributor I
if I set AP305 to max power 2.4Ghz and 5Ghz all time?
Can I use maximum power all time, what is any impact on my AP305?
thankyou.
Re: if I set AP305 to max power 2.4Ghz and 5Ghz all time?
I don't think it will hurt the AP.  Your client roaming performance could suffer, though.
Colin Joseph
Aruba Customer Engineering
