inforcing DHCP issue
dear all,
i'm using arubaOS 6.4.2.2.
enforcing dhcp is not working with me any idea or suggestion, do any  one know how it work.
Raouf CHAHBOUNE
ICT Network & Security Engineer
CCNP R/S | CCNA Security | ACMP|ACCP|ACDX
[If my post is helpful please give kudos, or mark as solved if it answers your post.]
Re: inforcing DHCP issue
When you say it is not working, do you have an example?
Are you configuring the correct AAA profile?
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
yes  i do it with guest network, i  used the same address given by the dhcp , with that i get access to the network .
Raouf CHAHBOUNE
If the controller sees your device get an ip address via DHCP it will allow the device to keep the same static ip address.  If you change it to a different static ip address, it should not work.
yes, i confirm,
the only problem that the dns is not enforced , even if the ip address is enforced, a the user can modify the dns ip address.
thank you
Raouf CHAHBOUNE
So your firewall policy for a user would be to only allow DNS traffic to a server you have defined.  The feature is "enforce dhcp" not enforce dns...
good idea, i will  do it
the dns ip address is given by the dhcp  so i finds logical that the controller enforce it .
regard
Raouf CHAHBOUNE
The enforce DHCP only enforces an ip address.  A DNS server is NOT an ip address..
Frequent Contributor II
You can enforce a DNS server by using destination NAT under an aruba user role. See this example that someone else did for chrome cast. You could modify rule to include all DNS server. I don't have best practice on this but I would allow DNS traffic to your server before doing dst-NAT.
http://community.arubanetworks.com/t5/Unified-Wired-Wireless-Access/Chromecast-DNS-Hard-code/m-p/141887/highlight/true#M30220
Hope this helps.
