Occasional Contributor I
instant 6.5.x iphone drops data connection - works fine with 6.4.x-x.x.x.x code anyone on 6.5.x?
instant firmware 6.5.x
anyone on 6.5.x? experiencing the same issues?
I can remember we had such problems before with a buggy firmware but this was almost a year ago - still there are now 3 different 6.5.x versions available all of them have the same problem in our environments (different sites)
6.5.0.0-4.3.0.0
6.5.0.0-4.3.0.1
6.5.1.0-4.3.1.0
Problem description
iphones connect and they seem to work fine
randomly the quit working in wifi (wifi shows connected but no data exchange is possible)
disabling and enabling will get them to work again for some minutes
switching to different ssid will also reinitialize to working mode
we don't experience this kind of problem with code running prior to 6.5.x
Re: instant 6.5.x iphone drops data connection - works fine with 6.4.x-x.x.x.x code anyone on 6.5.x?
Are you using enforce DHCP?
Hi colin
we are not using enforced dhcp
config:
network assigned dhcp
client vlan static
wpa2 code
no enforced dhcp
no blacklist
no mac auth
fast roaming r,k,v yes,yes,yes
SSID was hidden is now aired due to problems with the first ios 10 version
Take off r,k,v and fast roaming, because they add variables. You should be able to run it just feels be without all of that stuff checked..
