integrate between Aruba controller and asset Recovery application ,,!
Dears,
I have asset Recovery application named ( REMEDY ) need to integrate with Aruba controller to get all the AP’s information exactly the serial numbers / HW info for them. So,
1-      What is the type of AP’s DB is it ( SQL or Oracle )
2-      Does the communication used default port TCP # 1433
3-      What is the table name that is serving those information on the controller.
4-      Does I need special username / password different than the one that was used on the management accessibility.
5-      Is there any additional configuration need to added on the controller.
waiting for your kind support ,,:catvery-happy:
Re: integrate between Aruba controller and asset Recovery application ,,!
There is no SQL interface on the Aruba Controller.  The best way to obtain that information is using SNMP.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Do you have ClearPass?
Tim Cappalli | Aruba Security
