Contributor I
is Aruba 7240 Mobility controller supports LI (Lawful Interception)
Hi All,
Need your help in below query
is Aruba 7240 Mobility controller supports LI (Lawful Interception).
if yes then how?
Many Thanks in advance.
Prabhat
Re: is Aruba 7240 Mobility controller supports LI (Lawful Interception)
There is nothing formal in ArubaOS, but you can configure a session mirror destination, where you can send a copy of user traffic:  Please see session mirror destination here;  http://www.arubanetworks.com/techdocs/ArubaOS_64x_WebHelp/Web_Help_Index.htm#ArubaFrameStyles/Firewall_Roles/Global_Firewall_Paramete.htm
