Contributor I
is ap 61 compatable with 7030 controller .......
Hi all,
Is ap 61 compatable with AP 61.....pls help....
Thanks in advance.
Aruba
Re: is ap 61 compatable with 7030 controller .......
No.  The last version of code that the AP61 is supported (and other legacy non-802.11n APs) is 6.3.
The minimum version of  code for the 7005 controller is 6.4.1.0.
ACCP, ACMP, ACMX #294
mclarke@arubanetworks.com
