is there a limited devices for a Group
I have a Airwave with more than 1600 devices, and I have a group with more than 1400 devices. It's a problem??
I'm asking this because there are a lot of bad behavior from de AirWave like:
- after updating a template it takes more than 2  to 4 hours to show "Good" on status colum
- after adding a new device it takes more than 2 to 4 Hours to show "Good" on status colum
- there also devices that are in permanently verifying status
strange behaviors that I didn’t have at the beginning
We went to the version and the AppRF stop Working.
There are just to many issues and the Airwave is not doing is thing, like being a monitor tool for the IAP's
Re: is there a limited devices for a Group
You could have other things going on, so you should open a case with TAC.  Your problems might not be caused by having 1600 devices, but they could be a symptom of something else.  They can take a look at everything including network bandwidth, configuration and possible horsepower of your box to determine what could be the cause of your issues.
Colin Joseph
Aruba Customer Engineering
