is there is virtual Aruba controller that can be installed on ESXI?
  • 1.  is there is virtual Aruba controller that can be installed on ESXI?
    Posted Sep 15, 2016 08:43 PM
    I want to know the availability of aruba virtual controller please
  • 2.  RE: is there is virtual Aruba controller that can be installed on ESXI?
    Posted Sep 15, 2016 09:31 PM
    More info will come out in the next 4-6 weeks, supported in AOS 8.0.1.
  • 3.  RE: is there is virtual Aruba controller that can be installed on ESXI?
    MVP
    Posted Sep 16, 2016 04:23 AM
    And even with 8.0 the answer remains: it is not possible to connect APs to the virtual controller. You need a physical controller to do that, or go controllerless with instantAPs.
  • 4.  RE: is there is virtual Aruba controller that can be installed on ESXI?
    Posted Sep 17, 2016 09:14 AM
    Thansk guys for replaying buut  thing got more darker fro me as I don't understantd why Aruba OS 8 is totally diffrent from the 6.x.x versions please try to clarify.
  • 5.  RE: is there is virtual Aruba controller that can be installed on ESXI?
    MVP
    Posted Sep 17, 2016 09:53 AM
    The difference is called progress I suppose :)
    Going from version 2.5 to 3.0 also was a huge change. That turned out to be a good thing and so will 8.0... hopefully.
    8.0 will bring plenty of improvements. What those are will become clearer with time and increased marketing from Aruba.
  • 6.  RE: is there is virtual Aruba controller that can be installed on ESXI?
    Posted Sep 17, 2016 12:24 PM
    You would have to release notes to understand in detail why it is different.
    In general:
    - Centralized Licensing can be shared among controllers that are not running exactly the same version of ArubaOS
    - Centralized configuration provided among controllers that are not running the same version of ArubaOS
    - A VM instead of a physical controller provides the "master" function that manages configuration, Airgroup, UCC.
    You should read the release notes here:  https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/EntryId/22284/Default.aspx for more details.
  • 7.  RE: is there is virtual Aruba controller that can be installed on ESXI?
    Posted Sep 17, 2016 07:05 PM
    To add to Colin's list, we also have:
    * the ability to set license pools for groups of controllers so that they cannot exceed a certain value
    * Multizone
    * AirMatch (new ARM tool)
    * UCC enhancements and support for new voice and video protocols
    * Better WebCC
    * Better AppRF
    * More granular, and simple, control over large WLAN network deployments
    The release notes are a good place to start. From there, engage with your local Aruba sales team for more.
