Frequent Contributor II
legasy device not able to connect WPA2-AES
hi all,
One more question.
I have one SSID with WPA2auth and AES encryption enabledand auth server as AD [dont have CPPM].
Today i was trying to authenticate one legasy device [nokia 5800] with that SSID, but its saying EAP-peap authentication failed.
Is there anything to support legasy device with wpa2 -aes And also how can i troubleshoot why the client showing EAP-PEAP auth failed..
rana
Re: legasy device not able to connect WPA2-AES
Turn on user-debugging for the client and then run "show auth-tracebuf mac
Tim Cappalli | Aruba Security
Since this device only supports b/g try the following:
- Make sure that all your lower basic rates are enabled
- Create a test SSID with the same aaa profile and disable "band steering" on the VAP
Thank you
Victor Fabian
Lead Mobility Architect @WEI
how to turn on user debug....
plz tell me
rana
Logging level debugging user-debug <client-mac>
Band steering is disabled, and all the lower rates is also enabled
[Edit]  here is the O/P
Feb 18 06:07:21  station-up             *  00:25:48:c0:1f:89  00:24:6c:b2:2d:c0  -  -  wpa2 aes
Feb 18 06:07:21  eap-id-req            <-  00:25:48:c0:1f:89  00:24:6c:b2:2d:c0  1  5
Feb 18 06:07:21  eap-start             ->  00:25:48:c0:1f:89  00:24:6c:b2:2d:c0  -  -
Feb 18 06:07:21  station-down           *  00:25:48:c0:1f:89  00:24:6c:b2:2d:c0  -  -
Feb 18 06:07:32  station-up             *  00:25:48:c0:1f:89  00:24:6c:b2:2d:c0  -  -  wpa2 aes
Feb 18 06:07:32  eap-id-req            <-  00:25:48:c0:1f:89  00:24:6c:b2:2d:c0  1  5
Feb 18 06:07:32  eap-start             ->  00:25:48:c0:1f:89  00:24:6c:b2:2d:c0  -  -
Feb 18 06:07:32  station-down           *  00:25:48:c0:1f:89  00:24:6c:b2:2d:c0  -  -
Feb 18 06:08:01  station-up             *  00:25:48:c0:1f:89  00:24:6c:b2:2d:c0  -  -  wpa2 aes
Feb 18 06:08:01  eap-id-req            <-  00:25:48:c0:1f:89  00:24:6c:b2:2d:c0  1  5
Feb 18 06:08:01  eap-start             ->  00:25:48:c0:1f:89  00:24:6c:b2:2d:c0  -  -
Feb 18 06:08:01  station-down           *  00:25:48:c0:1f:89  00:24:6c:b2:2d:c0  -  -
rana
thanks Tim,
here is the O/P
rana
Can that device connect to an open SSID ?
Thank you
Victor Fabian
Yeah it able to connect Open network, Captive portal, PSK.
her eis the O/P of tracebuf
rana
Yes its able to connect open n/w , captive portal, psk,
Here is the output of tracebuf
rana
